by Tonto1300
How to make calls in france
How do i make calls in other eu countrys
by Tonto1300
France
Unable to to make calls in France
Re: How to make calls in france
@Tonto1300 : If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Hi there @Tonto1300
Welcome to the community.
If everything that @XRaySpeX has mentioned is all already active can you tr the below steps to select a different network?
  • iPhone > Settings > Mobile Data > Network Selection > Turn off Automatic
  • Android > Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows > Settings > Mobile Network > Network Selection > tap on start manual search
Hope you are all up and running now and having a great time in France 🙂
