by magdarynek
How to activate my pack from abroad?
I bought a new EE sim card but didn't activate it when I was in the UK. Then I bought a Talk &Text Pack online.
Now I am abroad and I cannot text, call or browse. When I try to call it says that the number is barred. How can I activate my sim card? Incoming calls are directed into a voicemail, and although I am active I receive a text that somebody tried to reach me. They can also text me, but I can't.
I will be grateful if you help me.
Re: How to activate my pack from abroad?
Hi @magdarynek
Welcome to the community.
We can't guarantee that a SIM card not registered on the EE network in the UK will work abroad.
You could try manually connecting to a different local network operator:
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
