Highlighted
New Member
How much will using my phone cost in America
I’m going to America in a month, I’m on the 4GEE Max Plan, how much will it cost to use my phone
Highlighted
Solution
Re: How much will using my phone cost in America
Hi @Deannalee
If you took the plan out after the 10/05/17 then the first 15GB if your allowance is free to use.
See here.
Highlighted
Solution
Hi @Deannalee
See here.
Recent solutions
