by Ghani
New Member
How much will it cost to use my data in Asia
Planning a round trip to Japan, Hong Kong, Shanghai and dubai.
Could you please confirm how the roaming data works regarding charges?
Thank you
Re: How much will it cost to use my data in Asia
Hi @Ghani
Welcome to the community.
When you arrive in each country, you'll be given an option to buy a data add-on to use your data. If you don't buy an add-on you won't be able to connect to mobile data. So there's no risk of unknowingly running up a large data bill.
Check out the roaming tool for Japan, Hong Kong, China and United Arab Emirates. The costs for data add-ons is on there.
It sounds like an exciting trip, I hope you have a brilliant time. 😄
