by Humber27
How much will it cost me to ring ee to ee from the Czech republic?
How much will it cost me to ring home ee to ee from the Czech republic when I travel there.
Solution
Re: How much will it cost me to ring ee to ee from the Czech republic?
@Humber27 You can use your EE allowance in the Czech Republic as it’s part of the EU and you can now use your EE allowances in the EU.  Just make sure roaming is enabled before you travel.   Text ROAMING to 150 to enable this.  You can do this now as there is no cost to have this enabled and it’s best to make sure it’s enabled before you leave the UK.
You can use up to 15GB of data per month if you have this or more in your data allowance.
Solution
by Humber27
Thats great thanks.
Sent from my Samsung Galaxy smartphone.
Morning @Humber27
Thanks for coming to the community,
I can see you have had a great answer from @Chris_B 🙂
If you need anything further let us know.
Have a great time!
