by anna-m Investigator
How much of my Data can I use in EU
Hi guys,
cant find any proper confirmation as most of links about EU roaming on ee website don't work!
I have 2GB of data on my personal EE plan + 5GB added because of broadband.
How much of it can I use in EU without additional charges. I thought all 7 GB, but while reading details of my plan I found info there is 500MB of free EU data. I have the plan from last year. But since june roaming charges were supposed to be abandoned? and there seems to be 15GB fair usage - so my 7GB would be within the limit...
Would love someone well informed to clear it for me, please!!
Thanks!
by Ace Contributor
Solution
Re: How much of my Data can I use in EU
HI,
@anna-m
Yes that is correct you can use 15GB in EU.
For more details please see this Fair use amount If your domestic data allowance is greater than 15GB .
Many Thanks
by Ace Contributor
Solution
HI,
@anna-m
Many Thanks
