by Bilbo69
New Member
How much is data usage in Africa (Gambia)
How much does data cost for The Gambia, Africa? What’s the cheapest plan, data/internet only.
by Star Contributor
Star Contributor
Solution
Re: How much is data usage in Africa (Gambia)
Hi @Bilbo69
this link will give you the costs and also info on purchasing data to use abroad. Hope this helps xx
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs
by Star Contributor
Star Contributor
Solution
Hi @Bilbo69
