Highlighted
New Member
How much does it cost to use data in the usa
Travelling to the US in a week, is there an add on I can buy to reduce my costs?
Mainly for data, not concerned about calls,texts.
Thanks.
Highlighted
Re: How much does it cost to use data in the usa
Good Morning @Martindh66
What price plan are you currently on? if you are on a Max Plan from 10 May 2017 then roaming within the USA is inclusive. You are able to use 15GB of your data and unlimited calls and texts to call around the USA and back to the UK.
If you are not on a Max Plan you can find roaming costs and add-ons here.
I hope this helps,
Katie 🙂
