by Lorna7
How much does it cost to text my son in Turkey
How much does it cost to text or call my son in turkey .
Re: How much does it cost to text my son in Turkey
Hi there @Lorna7
Thanks for coming here 🙂
If your son is visiting Turkey and using a UK number, this will come out of your allowance 🙂
If he is using an international number, you can check costs on our Calling abroad from the UK tool. All you need to do is enter Turkey and select pay monthly or pay as you g depending on your account type.
Leanne 🙂
