by Tari
How much data can I use in usa
I am due to visit USA and would like to know how much of my data can i use whilst there?
I have been told just 5gb but anything i have found on roaming indicates that i can use my whole data allowance whilst in USA
Solution
Re: How much data can I use in usa
@Tari   You can use up to 15GB per month from your allowance if your on a max plan. If your not on a max plan you’ll need to purchase add ons
text RO AMERICA to 150 to see what your options are.
Solution
by Tari
Thanks mate
Sent from my Samsung Galaxy smartphone.
