Highlighted
How do set data roaming up when already in Europe?
Hi, I forgot to set up data roaming before I came to Italy and now it won’t let me text or call anyone. Had a message saying that I can use my plan as normal and checked my phone setting and data roaming is switched on! Can anyone help me?
Highlighted
Re: How do set data roaming up when already in Europe?
@Gemma23: In your MyEE under Manage Device allow Roaming and Call Abroad & Premium Rate. If it won't let you you will need to call EE. Use the landline nos. in my sig.
Highlighted
Hello there @Gemma23
Thanks for coming here.
Has the advice from @XRaySpeX got your calls and texts working in Italy?
If not, can you try and connect to a network in the phone settings.
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Thanks. Leanne.
Recent solutions
