by mLe86
How do I use my data pack while in Iceland?
Hey, I'm on holiday in Iceland for a week and a bit and would like to use my phones data package while here. I got a text saying that it was possible, but also a notification saying that I can't since I had my mobile data turned off when I left my home (country I assume) I've been disconnected. Since I traveled on plane and put my phone into airplane mode I couldn't really keep it on.
So how do I reconnect? I tried going into settings/SIM and network/sim1/network operators but I can't find EE in the list.
Thanks in advance for any advice!
by mLe86
Solution
Re: How do I use my data pack while in Iceland?
I think I just figured it, I didn't have data roaming activated. 😒 First time using this phone abroad.
As you do in UK.
Make sure Mobile Data is ON & Flight Mode OFF.
EE doesn't run a network abroad. It uses one of its roaming partners. Find a local Network Operator you can connect to.
by mLe86
Solution
Welcome to the community, @mLe86
Glad you're sorted! Enjoy Iceland. I've never been before but it looks beautiful.
Chris 🙂
