by Salw249
How do I unblock outgoing calls from Europe? These should be included in my plan
i am unable to make any outgoing calls having just landed in Italy. Calls from Europe back to the Uk are included in my plan but I am being told they are currently blocked. How do I do undo this? Any help hugely appreciated!
Re: How do I unblock outgoing calls from Europe? These should be included in my
@Salw249  You can use your allowance when in the EU it does mean that roaming or even international and premium rate numbers are enabled on your account.
Do you have a signal on the device?  If you do then you need to login to your online account and enable international and premium rate numbers.  If you don’t have a signal on your device you need to login to your online account and wait for a live chat window to pop up so you can request that to is enabled on your account.
EE Employee
Hi @Salw249 and welcome to the community,
Have you managed to solve your issue following the advice given by @Chris_B?
If not please let us know and we will try to help further.
Many thanks,
Lee
