by Tracy1970
New Member
How do I unbar my phone so I can make calls from Portugal to the UK
How do I remove international call barring from my iphone?
Solution
Re: How do I unbar my phone so I can make calls from Portugal to the UK
Hi @Tracy1970
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
Solution
Hi @Tracy1970
Or
