by leostan23
How do I set up my Ee roaming?
I'm already in Germany, how do I set up my roaming? I'm using Samsung S9
Re: How do I set up my Ee roaming?
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Afternoon @leostan23
Thanks for posting on the community.
Has the advice from @XRaySpeX helped get your roaming set up?
Hope you are having a great time in Germany 🙂
