by bigd60springer Valued Contributor
Valued Contributor
How do I log into http://EE.mobilebroadband?
I have a data only SIM in a TP Link mi-fi and I want to use mobile phone and tablet as clients. It works fine in the UK, but not abroad. I need to access http://EE.mobilebroadband in order to autoconnect even when roaming. However, when I Google it the response says "Page not available, DNS server cannot be reached". Is there any other means of accessing this setting, please?
Solution
Re: How do I log into http://EE.mobilebroadband?
You were given some APN settings in post 37. THey would do just as well. Did you try them?
42 REPLIES 42
by Profile closed
Not applicable
Hello @bigd60springer try this link instead:
http://192.168.1.1
Valued Contributor
Sorry, but this site also cannot be reached
Valued Contributor
Thank you but this site cannot be reached
by Profile closed
Not applicable
Hello @bigd60springer when connected to your MBB device the link above should take you to the TP Link MiFi dashboard where you can access the devices settings. Are you connected to the device via WiFi? You can also try these links:
http://192.168.0.1
Or
http://tplinkwifi.net
Valued Contributor
Thank you again. However, the TP Link page relates only to TP settings, not the EE data SIM
by Profile closed
Not applicable
Hello @bigd60springer I am sorry you want to enable roaming on your EE account not your device? you can access your MY EE online account for your data SIM using this link
https://id.ee.co.uk/id/login
To check or change your roaming status navigate to MY EE>Manage device after signing in. 🙂
Valued Contributor
Thank you again. Sorry I'm being a pain but MyEE/Manage device just tells me roaming is enabled and I should be good to go. I need to access settings in order to enable automatic connection when roaming..
by Profile closed
Not applicable
Hello @bigd60springer if roaming is enabled on your account then you need to access the MBB devices settings to enable data roaming (auto connect when abroad). This is done using either http://192.168.1.1 or http://tplinkwifi.net.
What happens when you try to access them? Are you connected to the device via WiFi when trying to access them? Which TP Link model number do you have? 🙂
@Tom222 wrote:
http://192.168.1.1
http://192.168.0.1 for a TP-Link.
by Profile closed
Not applicable
I said try either http://192.168.0.1 or http://192.168.1.1 TP Link use both depending on the device/model.
Hi @bigd60springer,
Welcome back to the EE Community.
Have you had any luck using the links @Profile closed and @XRaySpeX provided?
Valued Contributor
Thank you again. IP addresses open but relate to my in house wired router. I can access settings for the mi-fi by connecting to it (no internet), then into set-up, but it does not relate to roaming. Status just says disconnected.
EE assure me I need to get at "automatically connect when roaming" under http://EE, but I'm unable to access it (DNS server not found).
Valued Contributor
Thank you, but no. I have to say I'm very grateful for the efforts of several respondents.
by Profile closed
Not applicable
Hello @bigd60springer you should be able to change it within the devices settings you are accessing when offline. You should be able to find it under settings>dial up>data roaming or similar:
http://uk.tp-link.com/faq-1649.html
@bigd60springer wrote:
IP addresses open but relate to my in house wired router..
You should not be connecting your device to your home BB but to the TP-Link when you issue those IP addys.
You cannot access the TP-Link's settings using an EE URL & anyway "http://EE" is incomplete.
Valued Contributor
Sorry, thought I had said http://ee.mobilebroadband
by Profile closed
Not applicable
Hello @bigd60springer to confirm have you got your device connected directly to the TP Link device via WiFi? Can you access the devices settings?
Why are you trying to use an EE URL to access a non-EE mobile router anyway? Have you remembered it from a previous EE mobile router you had? It would never had worked with a TP-Link router, neither in UK nor abroad.
Or was this something you were told by EE CS? They would only be talking about EE mobile routers & you weren't, but did you tell them that?
Valued Contributor
Thank you. Settings/dial up seems only to offer auto or manual connection. I'll try again when home this evening as I don't have the mi-fi with me now.
