by Angela10
How do I increase my mobile monthly data allowance
How can I increase my monthly data allowance and I am travelling to Austria tomorrow can I use my phone there at no extra cost?
Solution
Re: How do I increase my mobile monthly data allowance
@Angela10: You may use your UK allowances anywhere in the EU, incl. Austria, with your data limited to 15 GB / month if you have higher. If you run out of data go to http://add-on.ee.co.uk/purchase when not connected to WiFi to buy more.
by Angela10
Solution
Morning @Angela10
That is great advice from @XRaySpeX.
Full details on using your phone abroad can be found on our getting ready to use your phone abroad post.
Before you go, text ROAMING to 150 to make sure you're all set up to use your phone abroad.
Have a great time 🙂
