by James-maclaren
How do I get service in Berlin
Re: How do I get service in Berlin
Hi @James-maclaren
Welcome to the community, I hope you're having a fantastic time in Germany so far.  🙂
Please check to make sure roaming is enabled in your My EE account:
Log in > tap Menu > tap Manage device
As long as your roaming is enabled, your phone should search for an available network.
If you still can't find a connection, please try a manual network search:
Device type Steps
Apple Settings > Carrier > Toggle Automatic OFF
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know how you're getting on.
