by fongbb
How come I do not have signal in Taiwan?
Hi, I have pay as you go scheme and have been abroad for 1.5 months now where I haven't been using the EE sim card. I put it in just now to make sure I still have regular "activity" so that I can keep the number. But there's no signal (It used to have when I've just arrived here in Taiwan). Is there anything I should do? Thank you.
Solution
Re: How come I do not have signal in Taiwan?
Hi @fongbb
Welcome to the community. 🙂
Could you try manually selecting a network please?
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know if that helps you get connected.
Solution
Hi @fongbb
Device type Actions
