by Andywhite84
New Member
How can I remove the international bar?
I can’t sent texts or call from abroad, how can I remove the international bar?
thanks
Solution
Re: How can I remove the international bar?
@Andywhite84 : If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Solution
