by torki
New Member
How can I recieve calls from UK when I am in Turkey?
And Is there any charge for recieve call without answer it?
EE Employee
Solution
Re: How can I recieve calls from UK when I am in Turkey?
Hi and welcome to the Community @torki
As long as your account is set up for using abroad, you should be able to accept calls as normal.
Please do see our How To Use Abroad guide as all the information you need is there.
For charges, please do pop over to charges page regarding Turkey.
Many thanks,
Lee
EE Employee
Solution
Many thanks,
Lee
