by Xaafada10
Hi
I am abroad and i have got problem calling back in the uk I can't even call 150 and I desperately need to call back home please help
by Ace Contributor
Re: Hi
@Xaafada10
Did you turn your roaming on before travel?
Please click to check on Manage your device
If you see there  Roaming not enabled then click on ENABLE ROAMING.
Many Thanks
EE Employee
Re: Hi
Hi @Xaafada10 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447*********, did this work?
Also, please let me know If you are using an EE personal or business account as I may be able to assist with our live chat service?
Many thanks,
Lee
