by Markcoburn
Hi, using an EE PAYG data card in Italy on TP-Link M7350 mobile wifi - settings?
Hi, would anyone perhaps know the correct APN and Network settings, when using this device in Europe? Many thanks Mark
Solution
Re: Hi, using an EE PAYG data card in Italy on TP-Link M7350 mobile wifi - setti
@Markcoburn Its the same as what you use in for the UK as your roaming.
Solution
by Markcoburn
Many thanks Chris, all sorted now
Morning @Markcoburn
Glad you got the help you needed from the community.
Have a great time 🙂
