by lindsaypienaar1
New Member
Hi there can I use my mobile phone in Guernsey
Can I use my mobile phone in Guernsey
by Ace Contributor
Re: Hi there can I use my mobile phone in Guernsey
Hi @lindsaypienaar1, yes you can use your allowance in Guernsey.
Hello @lindsaypienaar1
Thanks for coming to the community .
If you are travelling to Guernsey, you can use your minutes, texts and up to 15GB of data from your allowance 🙂
If you have a pay monthly account with us, before you go make sure you are set up to use your phone abroad 🙂
You can do this by texting ROAMING to 150, or you can log into your My EE account online go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium rate> They will show as ticked if roaming and calling abroad is activated.
Let us know if you have any questions.
