by 74charger
Hi, is WiFi calling free when abroad? Get conflicting answers online
Solution
Re: Hi, is WiFi calling free when abroad? Get conflicting answers online
@74charger  WiFi caking doesn’t work abroad it’s for UK use only.  And if it did depending on where you are in the world you would be charged for calling.
by 74charger
Thanks for responding, much appreciated
Sent from my iPhone
by Brilliant Contributor
No, it'll be classed as roaming.
Solution
