by SoniaP Investigator
Hi i have a question about my plan
Hi i have a question about my plan If I Going to France My Plan and Internet its ok or i need anything else ? thanks
Solution
Re: Hi i have a question about my plan
@SoniaP: Yes, it is part of EU. You may use your allowances there with up to 15 GB data per month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
Hi
If have a contract ! if I active the ROAMING  before i leave, how much it is or its included in my plan ?
It costs nowt. It's just part of EE's procedure. You only need do it the 1st time you go abroad to get your a/c enabled for roaming.
