by Hacky79 Investigator
Hi, going to Australia, on a monthly plan. I'm guessing it's roaming I use?
6 REPLIES 6
by Brilliant Contributor
Re: Hi, going to Australia, on a monthly plan. I'm guessing it's roaming I use?
@Hacky79 ,
Have you taken a look here to make sure your phone is ready for use abroad:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Getting-ready-to-use-your-phone-abroad/td-p/749932
Yes you will need to make sure your phone is set up for roaming and it is switched on, but please check the link for further information, as you need to make sure that in your account premium and international calls are enabled.
Hope you have a good time, never been there myself, whereabouts are you going?
Hi @Hacky79,
Which plan are you using?
Hi James,
On an 10gb essential plan
Thanks so much, I'll check the link out.
Long trip, Gold Coast and Barrier reef first then Sydney, Melbourne, ending up in Perth, can't wait tbh
That trip sounds amazing, @Hacky79 😮
You won't be able to use your normal plan allowances in Australia. You can add the Go Further add-on (or swappable if you have swappables on your plan).
This would allow you to use your normal call, text and data (up to 15GB) allowances when in Oz.
@Hacky79 , Glad to help, hope you have a lovely time, as @Christopher_G wrote , that trip sounds amazing, not sure whether I will ever go to Australia, so many exciting places to visit around the world.
