by ANGIEZWB15
New Member
Hi I'm travelling to Norway ,do I turn data roaming off or can I use it
Solution
Re: Hi I'm travelling to Norway ,do I turn data roaming off or can I use it
You may data roam there. It is part of EU. You may use your usual allowances there with up to 15 GB data per billing month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
