by ShaniaLeo
New Member
Hi I’m just wondering if I get charged for using my data in turkey
Solution
Re: Hi I’m just wondering if I get charged for using my data in turkey
You can't use your normal data there, as it's not in EU. You will need to buy a data add-on as set out in https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/turkey... .
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
