by Vin21all Investigator
Hi I’m Canada and on a 4g plan but phone is showing no servic
8 REPLIES 8
Re: Hi I’m Canada and on a 4g plan but phone is showing no servic
Hello there @Vin21all
Can you try and select a different network on your device as below;
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know how you get on.
Ho Leamne,
Thanks for your reply I have tried that and switched on and off but still no service.
Vinny
Sent from my iPhone
Hi, still showing no service, is there anything else I could try
Thanks for trying @Vin21all
It may be that your account is not set up for roaming.
You can check this and if needed turn this on as below;
If you log into your My EE account online and go to Menu > Manage Device > Roaming Abroad > This will show as ticked if roaming is activated.
Let me know if this works for you.
Hi Leanne,
I’ve went in and pressed the unblock button but may take 24hrs so hopefully works.
Thanks for your help
Vinny
Sent from my iPhone
No problem @Vin21all
Let me know how it goes if you can 🙂
Have an amazing time in Canada!
Still no luck getting access
Sent from my iPhone
Morning @Vin21all
Thanks for coming back to me.
In this case, I recommend logging into your My EE account on your phone's browser (not the app) or a computer.
Once you're logged in, a chat window will pop up when an advisor is available.
They will be able to get this looked into for you.
Thanks, Leanne.
