by Davidmccallum18 Investigator
Hi I have business plan with 180mins from USA, just arrived and can't call uk?
Hi I just arrived in the USA and I have a business plan with 180 mins of call time to and from USA. When I try and call I am told it's restricted or call customer services, which I can't as it's restricted. Anyone help.
9 REPLIES 9
EE Employee
Re: Hi I have business plan with 180mins from USA, just arrived and can't call u
Hi @Davidmccallum18 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447*********, did this work?
Many thanks,
Lee​​​​​​​
by Brilliant Contributor
@Davidmccallum18 On a business plan you should be able to activate and deactivate roaming yourself I can on mine log into my Ee then manage device then device usage controls.
the option to allow roaming is there on my account
EE Employee
Hi @Davidmccallum18
Have you managed to activate your line by following the advice from @Damienw1.
Many thanks,
Lee
Hi Lee
yes followed advice from Damien and roaming is activated but still no luck. Not sure if it will take time before I can call.
EE Employee
Hi @Davidmccallum18
Please do try manually selecting a different network other than the one you are connected to, just to see if that helps,
Lee
Hi Lee
still won't let me dial. Will be having words with EE when I return.
EE Employee
Hi @Davidmccallum18
I understand your frustration with this issue.
You can give us a call using another device or method.
Many thanks,
Lee
Hi Lee
what number is the best to call on.
thanks
David
Hi @Davidmccallum18
Thanks for coming back to us.
You can see all our contact numbers on the get in touch page here.
Thanks, Leanne 🙂
