by philip2761 Investigator
Hi I have a PDP authentication failure message ever since I arrived in Mauritius
Hi I gave PDP authentication failure message in Mauritius ever since I arrived. Wi-fi is fine. Roaming always worked abroad before with a data add on. I have iPhone 8. Help! Thanks
7 REPLIES 7
Re: Hi I have a PDP authentication failure message ever since I arrived in Mauri
Can you make & receive calls and texts?
Yes
Sent from my iPhone
Hi yes I have. My wife’s phone has the same issue if that helps. Same phone and same network
Sent from my iPhone
@philip2761   Your devices haven’t registered correctly with the network although it can see it that’s why your getting this error message.  All you can do is restart the device and give it time.  It should connect correctly but you’ll need to give it time.
Thanks but still not working. Been here 4 days and switched phone off countless times. Is there a Plan B?
Sent from my iPhone
Good Morning @philip279.
I hope you're having a fantastic time abroad.
Have you tried manually selecting another network? you can do this by following these steps:
Settings > Mobile Data > Network Selection > Turn off Automatic
Speak soon,
Katie 🙂
