by Ochman
Hi I can not use Roaming
Hi I am now abord and I can not use Roaming
Solution
Re: Hi I can not use Roaming
@Ochman : If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Solution
Good Evening @Ochman.
Thanks for coming to the community for help.
I can see @XRaySpeX has provided you some perfect advice, please let us know how you get on.
Katie 🙂
