by Noormalik96
Hi,I am using my EE max plan in the USA. Why is my carrier showing T-mobile?
 I switched to EE max plan before coming to the USA. I initially wasn’t able to use my data or anything but have access to it now after turning data roaming on but my mobile carrier is showing as T-mobile not EE?? I’m confused as to whether this data I’m using is from my plan or wil I be charged for this on a normal roaming rate. I got a message confirmation upon landing in the USA that my EE Max plan is ready to use.
Does anyone know how it works??
many thanks!!
by Ace Contributor
Solution
Re: Hi,I am using my EE max plan in the USA. Why is my carrier showing T-mobile?
There is no EE network in the USA.
They have roaming agreements. You are connected to the T-Mobile US network.
You will be using your MAX allowance.
BrendonH (Android Expert) - Samsung Galaxy S10+ (Pie 9.0) - Samsung Galaxy Watch (Tizen 4.0)
If I have helped you please click on the STAR/SOLUTION buttons below
by Ace Contributor
Solution
Hello there @Noormalik96
Thanks for posting on the community.
I can see you have had your question answered by @BrendonH
Let us know if you need anything further 🙂
by Scholarly Contributor
Facepalm
