by rikkimcadam Investigator
Hi, I am currently in Australia on the New Max Plan and cannot use my data.
Hi, I am curretly in Austalia on the New Max 4G plan and currently unable to use the data on my plan, even though it says there is good signal and 4G reception. i have also already sent ROAMING to 150
by Ace Contributor
Solution
Re: Hi, I am currently in Australia on the New Max Plan and cannot use my data.
Try removing the maxtravel add on if you can. A number of us have had this
issue with it. You may need to call and ask them to refresh your network
settings for it to take effect immediately though.
12 REPLIES 12
by Ace Contributor
Solution
Can you make calls & texts?
hi yes i have been able to make calls and texts
EE Employee
Hi @rikkimcadam and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Try then using data.
Did this work?
Many thanks,
Lee
by Ace Contributor
@rikkimcadam You haven't added the MAXTRAVEL add on have you?
Can you get to http://add-on.ee.co.uk/ and does it tell you anything intersting?
What happens when you try to browse to somewhere like http://neverssl.com ?
Hi
I think i have added the max travel plan...
i was able to go to each of those links where it said i was in australia then prompted me to buy data. but that shouldnt be so as it was confirmed by EE that its included in my plan
Hi yes i tired this and still did not maka difference.
great thank you ill give them a call now
by Ace Contributor
I can't see my reply, not sure what I've done.
Removing the maxtravel add-on would be a good step as a number of us have had this issue.
The reason I said to try neverssl.com was to see if it redirected you to the add-on page. If it does, it means the problem is your account, if it doesn't, it's likely to be your phone.
@chistery: Your post is 2nd in-line of this thread dated Yesterday & numbered post 1.
The Community lately has a nasty habit of backdating posts posted now to the past & the thread then files it chronologically, bar the OP itself. All v. confusing! Nowt seems to be being done about it, @Lee_H :(.
Thank you for your help i was able to get them to reset the network settings,
they also recommended that you text
STOP MAX TRAVEL to 150 and then YES to remove the add on from your plan
by Ace Contributor
Great, glad it's now working @rikkimcadam. Enjoy  the rest of your time down there!
