by Yvonne170
Hey guys , can we use our phone in Thailand? (Our minutes/ txts / data etc)
Solution
Re: Hey guys , can we use our phone in Thailand? (Our minutes/ txts / data etc
Hi @Yvonne170
If roaming is activated on your device (text ROAMING to 150) then yes, but you will need to buy an add on for data and calls, or pay the international rates.
Information on the cost of using your device in Thailand, and add ons can be found here
Solution
Hi @Yvonne170
