by Bigbearmummy
Help! struggling in Amsterdam.
Help! Nothing working in Amsterdam apart from data. No voice calls or texts permitted back to UK. Reregistered but no change. All worked fine in USA so why am I having trouble in Europe?
by Bigbearmummy
Re: Help! struggling in Amsterdam.
Hi
Thanks for your reply- done all that, still stuck. Reregistered but no joy. Frustrated!
Sent from my iPhone
by Brilliant Contributor
Hello @Bigbearmummy,
Welcome to the community,
Have you checked here:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-What-to-do-if-you-re-having-problems-abroad/td-p/66...
Also have you tried doing a manual search for a network to see if that works? Try +44 or 0044, see if that makes a difference, make sure that your phone is not in airplane mode and try rebooting your phone.
Hi @Bigbearmummy
Welcome to the community, I hope you're having a brilliant time in Amsterdam. 🙂
Could you try logging into your My EE account and make sure that your roaming and international calling is enabled?
OK, thanks for checking, @Bigbearmummy.
Could you try doing a manual network search and selecting a different available network?
Device type Steps
Apple Settings > Carrier > Toggle Automatic OFF
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know if that works.
