by Donkeybob
Help. No international calls. How do I turn off international barring no pun
Where do I get pin from? In Italy with no phone calls.
Re: Help. No international calls. How do I turn off international barring no pun
@Donkeybob   Log into your online account and see if you can enable this yourself.  The option can even be within the my EE app.
EE Employee
Hi @Donkeybob and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
