by Steveb33
Help I can't make calls or text from France. Data works however
Hi I can't make calls or make texts from france
by Profile closed
Not applicable
Re: Help I can't make calls or text from France. Data works however
Hello @Steveb33 since data is working I assume roaming has been enabled on your account? You can check by logging in to MY EE online and navigating to MY EE>Manage device:
https://id.ee.co.uk/id/login
Have you restarted the device since landing? Here is a link containing more information on troubleshooting problems when roaming abroad:
https://community.ee.co.uk/t5/Roaming/Roaming-with-EE-What-to-do-if-you-re-having-problems-abroad/td...
Hello @Steveb33
Welcome to the community.
Has the great advice worked from @Profile closed?
Thanks, Leanne 🙂
