by JDmiers
Help. Can’t make calls whilst abroad
Hi
i abroad at the moment and I need to make some urgent calls to the UK. Whenever I dial a number however there is an automated message saying calls are restricted. My roaming setting are all fine. Please can you help?
many thanks
Re: Help. Can’t make calls whilst abroad
Hi @JDmiers
Thank you for coming to see us 🙂
When you are preparing for your trip abroad, it is essential that roaming is activated before you go away.
In order to do this, all the information/set-up instructions can be found in our EE roaming - Getting ready to use your phone abroad support article.
I know on this occasion, you were aware that you needed to do this.  I know it's not working at the moment for you.
However, we can help.
Have you tried a manual network search?
How do I do a manual network search?
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
If this hasn't worked.
Please take a look at some of the hints, tips and tricks to get activated in our EE Roaming - What to do if you're having problems abroad support article.
If none of the advice in the support article works, you may have an international bar present.
This will need account access at this point.
If you are a pay monthly personal EE customer, then log in to My EE and await a chat with an online advisor.
If you can't access this, then please call customer services from an alternative landline or mobile.
Please let me know how you get on.
Cheers
Richard
