by Robinsonrr8599
New Member
HelloI am traveling to America can I use my allowances when I’m there
EE Community Team
Solution
Re: HelloI am traveling to America can I use my allowances when I’m there
Hi @Robinsonrr8599,
Welcome to the community 🙂
Do you know which plan you are on? If you moved to a Max plan after May 2017 then you will be able to use your allowances in USA like you would in the UK.
If you are not on a Max plan, then you will be charged for call and texts whilst roaming in the USA. To use data abroad that isn't inclusive, you will need to purchase an add on once you land in America.
Alex 🙂
by Brilliant Contributor
@Robinsonrr8599 It depends. What plan are you on?
EE Community Team
Solution
Hi @Robinsonrr8599,
Alex 🙂
