by DAmadis
Hello. I'm already on holiday and can't make calls or text. I sent a roaming
EE Employee
Re: Hello. I'm already on holiday and can't make calls or text. I sent a roaming
Hi @DAmadis and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Which country are you in?
Many thanks,
Lee
