by Phcpbank
Have 4G Max plan from Jan 2018. Going to USA. Do I need to turn on roaming?
I need to know what to do....
Have a 4G max plan from Jan 2018 and am going to USA. This is included in my package. Do I need to turn on roaming on my phone when there or will it just connect and I will have full usage? Thanks
Solution
Re: Have 4G Max plan from Jan 2018. Going to USA. Do I need to turn on roaming?
Hi @Phcpbank
Text ROAMING to 150 and you will receive a text to confirm if the service is active.
You can also check via your online account.
Solution
Hi @Phcpbank
by Phcpbank
Done. Thanks
