by Hatty65
New Member
Going to vegas . What's my best option on my phone
by Brilliant Contributor
Solution
Re: Going to vegas . What's my best option on my phone
@Hatty65 , hope you enjoy Las Vegas, it is an experience, to be honest!
Please make sure that you have set up your phone for roaming, if you have not already done so, as written here:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Getting-ready-to-use-your-phone-abroad/td-p/749932
Hi @Hatty65
What plan do you have?
If you have a swappable plan then use the Roam Further Pass. Or subscribe to this service. If you still have a Max plan from 10/05/17 then you can roam as at home.
Solution
