by Ringer
New Member
Going to Turkey
I am going to Turkey and don't want a huge bill on my return. Any tips on what and what not to do. Thanks
Re: Going to Turkey
@Ringer  Text RO TURKEY to 150 to see your options.   Don’t forget to text ROAMING to 150 to enable roaming on your account and also from within your EE online account enable call abroad and premium rate calls.
Re: Going to Turkey
Hi there @Ringer
Welcome to the community.
I can see you have had some great advice from @Chris_B 🙂
Just to add, you will be charged the normal incoming call rate for Turkey if someone leaves you a voicemail message, If you call the voicemail number to retrieve a message, you will be charged the outgoing call rate for Turkey.
All charges can be found on our EE Roaming tool.
If you prefer you can text VM OFF to 150 before travelling and when you return text VM ON to 150.
Full information can be found within our EE Roaming - Getting ready to use your phone abroad support article.
Hope you have an amazing time and let us know if you have any other questions.
