by cj2020
Going to Turkey on a 4GEEmax plan
I am going to Turkey soon and trying to find out the costs for data roaming. I am aware I can buy a travel pass at £5 per day (if used) but how much would data cost without the pass ?
EE Employee
Solution
Re: Going to Turkey on a 4GEEmax plan
Hi @cj2020 and welcome to the community.
The £5 per day is your best value for data, as if you were to buy a bundle they start from £4 for 40mb for 24hours use.
All details can be found on our Turkey roaming page.
Many thanks,
Lee
EE Employee
Solution
Many thanks,
Lee
by cj2020
Thank you very much
