by Jw76
New Member
Going to France is it as simple as just turning mobile data roaming ?
by Ace Contributor
Solution
Re: Going to France is it as simple as just turning mobile data roaming ?
Hi @Jw76. Welcome to the community. You should also check your account is set up for roaming, please follow this excellent guide which will help you ensure it's all set up.
Any questions, let us know and enjoy your trip!
by Ace Contributor
Solution
Hello there @Jw76
I can see @chistery has provided you with all the information you need, before you travel to France.
Hope you have a brilliant trip and come back to the community anytime 🙂
