by CJones Investigator
Going abroad
I am going to Belgium on Thursday, what must I do to ensure I don’t get any extra charges to use my phone to call home, text, use my data etc, is that even possible?
thanks
Re: Going abroad
It is part of EU. You may use your allowances there with up to 15 GB data per month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
by Profile closed
Not applicable
Re: Going abroad
This gives me an opportunity to give some information AND ask a question. @CJones, during your journey make sure that you don't connect to a satellite phone service. That would be very costly. Some ships have them. I don't know about Cross Channel Shipping, the Channel Tunnel or aeroplanes. And once you get to your destination you should restart your phone. https://shop.ee.co.uk/international/travelling-abroad @XRaySpeX, I tested my mobile today by texting Roaming to 150 and I got a reply saying that it's set up to Roam. But, I notice on my Android phone that in Settings, More, Mobile Networks, Data Roaming. Well, at present it is Off. Must I toggle that to On if I go abroad? And if so then when must I toggle that to On? I'm not going abroad soon but I've been wondering about this after seeing people having Roaming issues on here.
Re: Going abroad
@Profile closed: Enabling roaming on your EE account is for roaming in general, calls+text+data. The data roaming option on your phone is to allow it to be used for data while abroad. Only switch it ON while you need data.
by Profile closed
Not applicable
Re: Going abroad
Hmmm, in that case am I right in saying that effectively you have to triple unlock to use data abroad? First, there's to make sure that you are Roaming Enabled by EE, second is to toggle Data Roaming to On on your actual phone, and third is to have Data toggled to On? So, basically you have two safety settings on your actual phone if you want to not use data abroad which you can use, right? But, also if you do want to use data abroad you have to have all 3 On, right?
Re: Going abroad
@Profile closed: Right! However I'd expect many will have Mobile Data ON most of the time. I do!
