by Ana07 Contributor
Going abroad
  • Hi,
  • I'm going to Spain and Portugal next month. How can I upgrade to use my phone abroad?
Solution
Re: Going abroad
Hi @Ana07
If you get in touch with our customer service team they can make sure this is activated for you.
You can use your allowance in the EU that you have in the UK.
Thanks 🙂
11 REPLIES 11
by Profile closed
Not applicable
Re: Going abroad
Hello @Ana07 upgrading your phone and enabling roaming on your account are two separate services. To clarify do you want to upgrade your phone as well as enable roaming or keep your current phone and just enable roaming? 🙂
Re: Going abroad
I need a roaming.thanks
Re: Going abroad
Hello there @Ana07
Welcome to the community.
Are you with us on pay as you go or contract?
Thanks 🙂
Re: Going abroad
Yes
Re: Going abroad
@Ana07   thats yes to what  CONTRACT OR PAYG ?
Re: Going abroad
I've got pay as you go contract and I don't want another phone to upgrade just to go on broad tariff for a month. Thanks
Re: Going abroad
@Ana07  No such thing as a payg contract.
A contract is you've agreed to pay a set amount each month until the minimum term has been reached.  this will be 12/18 or 24 months
A payg is you top up each month to get an allowance from that top up and your not obliged to pay each month a set fee.
if your PAYG you can use your allowance from your PACK in the EU, and you dont need to do anything to get this to work abroad as all paygs are go to go abroad.
Re: Going abroad
Hi @Ana07
As @Chris_B has advised on pay as you go you can use the device abroad already.
You can use the allowance within the EU full information can be found here.
Thanks 🙂
Re: Going abroad
I've got contract and I'm paying monthly direct debit. How can i buy one month roaming to use my phone abroad. Thanks
Solution
Re: Going abroad
Hi @Ana07
Thanks 🙂
Re: Going abroad
@Ana07: As you are on a monthly contract you should text ROAMING to 150 & follow its instructions to ensure roaming is enabled on your a/c. Only PAYG contracts are auto enabled for roaming.
