by Jharris11
Going abroad tomorrow
I’m going abroad tomorrow to Turkey I want to know if I can use my phone over there ?
by Jharris11
Re: Going abroad tomorrow
Thank you
It says my phone is not set up for roaming and I know it’s too late to call now
Sent from my iPhone
@Jharris11: Text ROAMING to 150 before you leave to check your a/c is set up for roaming.
You should be able to use it there but it will cost. See https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/turkey... .
@Jharris11   Yes you can but make sure you text ROAMING to 150 now as you need to make sure roaming is enabled on your account.   Unfortunately you will not be able to use your allowances while in Turkey as Turkey is not part of the EU.
Text RO TURKEY  to find out what options you do have to keep costs down.
EE Employee
Hi @Jharris11 and welcome to the community.
I hope the information provided by @XRaySpeX and @Chris_B has helped. 🙂
If once you get to Turkey and you experience issues with your phone, please follow our wonderful guide for problems abroad whilst roaming.
Many thanks,
Lee
EE Employee
Hi @Jharris11
Are you overseas or still in the UK?
Many thanks,
Lee
